GR Yaris - minus 17kg with a lighter battery (LiFePO4)
Replacing the battery is a quick and easy way to save up to 17kg of weight. Liteblox.de has a modern LiFePO4 battery in their shop which could be worth a consideration. It is normally expensive for a litium iron phosphate battery (around 1.200 €) but brings only around 2kg with it. The OEM battery is a standard ~20kg block.
